1. ahampton0217#AC's Avatar
    This is my first post and need some help with my EVO I have it rooted and the battery dies quicker than it does before it was rooted any way I can save battery I do have an extended battery on it now and seems to help some. Another question is how can I get rid of the lock screen that you have to pull down to unlock the phone.
    Thanks to who ever helps me out
    08-01-2012 08:57 AM
  2. piizzadude's Avatar
    Just rooting does nothing to your battery. The culprit lies elsewhere.
    You can try nolock from the market to get rid of the lockscreen
    08-01-2012 09:19 AM
