1. rubenmungia's Avatar
    I just bought a new SD card for my HTC Vivid. I like to download podcasts and save them but I guess it was saving them to my phone's memory and I cant figure out how to download podcasts to my SD card. Please Help!
    08-12-2012 09:32 PM
  2. Devinator's Avatar
    How are you downloading them? Through an app? If so, check somewhere in the settings to see if there is a download path and change it to your SD card.
    As for the podcasts you've downloaded already, you should be able to move them. You could do so with a file manager, or, plug your phone into your computer VIA USB and move the files that way.
    08-12-2012 10:07 PM
