1. peacenrespect's Avatar
    How do I block / unblock text recipients ? Galaxy s3 sprint
    08-13-2012 02:43 PM
  2. still1's Avatar
    Use this app https://play.google.com/store/apps/d...ks.CallFilter2
    Its light on resource and have no impact on battery usage. above all it work perfectly.
    if you use avast it has text blocking as well just an fyi.
    08-13-2012 03:11 PM
