1. kittycatspawz's Avatar
    I have done a battery pull, as well as restarted, and rechecked the boxes for repeat sound notifications for my text messages. The repeat sound is set at every 2 minutes. I do receive the original sound notification, but, I never get the subsequent notices. Verizon is at a loss...gee imagine that...But, at the same time, the Haptic (vibrating touch) randomly unchecks it's box and I lose that function about every 2-3 days also.
    A complete factory reset is such a pain (any suggestions for a good way to do a restore would be ever so appreciated!) that I have held off doing it just in case there is an alternative in the forums.
    Anxiously awaiting y'alls reply
    08-13-2012 09:26 PM
  2. Devinator's Avatar
    Where is the check box for repeat sound notifications that you are setting?
    08-14-2012 07:55 AM
