1. giper54's Avatar
    If someone is interested in future Nexus phones are they better off with AT&T or Verizon?
    08-18-2012 11:47 AM
  2. dmmarck's Avatar
    GSM. Let's the user pick with more options available.
    08-18-2012 11:50 AM
  3. anon(847090)'s Avatar
    GSM!!! I will stay away from ATT... they make load of money + they are greedy and they screw up their customers... I want to give T mobile and US cellular a chance.
    08-18-2012 03:56 PM
  4. Va1ha11a's Avatar
    Plus the carrier has no control over the phone (the Verizon gnex, the sprint gnex, and the sprint nexus s don't have jelly bean yet, which is the point of nexii.
    08-18-2012 08:24 PM
  5. yodatom10's Avatar
    GSM straight from the Google playstore
    Sent from my Jelly bean powered Galaxy Nexus
    08-19-2012 10:23 AM
  6. Rukbat's Avatar
    Which network is better depends on where you live. No single network provides coverage all over.
    First decide which network provides the best coverage where you need coverage (home, shopping, school, work, etc.) Then you'll know which phones you can use. (The Verizon version of the Nexus is a lot more expensive than the GSM version.)
    The last decision is the carrier. For instance, you can use both the AT&T network and the Verizon network (not with the same phone, of course, or with a single account at one time) by choosing Straight Talk as your carrier.
    08-19-2012 03:59 PM
