When i turn my tablet on i get a battery symbol with a triangle around it and exclamtion mark in middle
what can i do to fix this please help
I know its a tablet but any chance its has a removable battery? if yes, remove it and place again.i did let it charge and it finished charging and tried hard reset and still get same thing
dont do that. you might damage the device.should i try undoing the battery cables ??
