jQuery: Show\Hide
Dargonight
5
On my web site I use jQuery to open and close <div> to save space in displaying information. When I move it to a mobile app, it doesn't work. I did conversion using from web to mobile using PhoneGap 2.0. Any idea on how to fix this or do I just need to display separate pages for each <div>?
thx
here the show/hide jquery:
// JavaScript Document
$(".mainDiv ul li a.topLevel").each(function () {
if ($(this).attr("class") == "on") {
$(this).attr("title", $(this).text() + ", Submenu Open");
$(this).next().show();
else {
$(this).attr("title", $(this).text() + ", Submenu Closed");
$(this).next().hide();
$(".mainDiv ul li a.topLevel").click(function () {
var $checkSub = $(this).next("div");
if (!$checkSub.is(":visible")) {
$(".mainDiv li div.mainDivSub").slideUp("fast", function () {
$(this).closest("li").find("a:first").removeClass("on");
$(this).closest("li").find("a:first").attr("title", $(this).parent().find("a:first").text() + ", Submenu Closed");
$checkSub.slideDown("fast").focus();
$(this).addClass("on");
else {
$(this).removeClass("on");
$checkSub.slideUp("fast");
return false;
var $checkSub = $("div.mainDivSub");
var $divWithFocus = null;
$checkSub.focus(function () {
$divWithFocus = $(this);
}).blur(function () {
$(document).keypress(function (event) {
if (event.keyCode == 27) {
$divWithFocus.slideUp("fast");
var $link = $divWithFocus.prev();
$link.removeClass("on");
$link.attr("title", $link.text() + ", Submenu Closed");
$link.focus();
and part of the HTML
<div id="container">
<div id="header">
<h1><a href="#">PDF Requirements</a></h1>
<div class="mainDiv" id="utility" role="navigation">
<ul class="mainDivUL">
<li>
<a class="toplevel" href="#"><span class="mainDivHeader">Document Properties</span></a>
<div class="mainDivSub">
<ol>
<li>
Ensure that the document is not scanned and content contained in the document is not scanned.
</li>
<li>
Scanned content must provide equivalent textual representation that can be interpeted by assistive technology.
</li>
<li>
The language of the document was been set under File Properties, Advanced.
</li>
<li>
The title and and author's name is in the File Properties under Description. Email addresses are not acceptable, Name(s) must be separated by spaces and provide academic credentials if available.
</li>
<li>
Set the Page Order under Page Properties. This is also know as Tab Order.
</li>
<li>
Ensure that the Tag Order, in the Tags Tress, is correct. Assistive technology will use the Tags Trees to determine how to read the document.
</li>
<li>
Make sure the Reading Order is correct on the page.
</li>
<li>
Ensure that Unicode codes are properly mapped or set to background if it does not provide content to the document.
</li>
</ol>
</div>
</li>
akbarramadhani12
