1. liberace's Avatar
    I accidentally deleted the system error sound on my Samsung galaxy advance S using Gingerbread.
    How can I reinstall the sound without rooting or complicating procedures. I am a new and bought my first android phone last week.
    Thanks for your help in advance
    08-25-2012 10:23 PM
  2. Devinator's Avatar
    If you can find the sound file somwhere, I would think you could just put it back in whatever directory it was you deleted from (named the same file name) and you'd be fine, no? Do you know anyone with a phone that has the same sound? Or you could try looking for it on Google.
    08-26-2012 09:23 AM
