1. nexusisneecesary's Avatar
    Hello how many of you are on 4.04 ICS and have encountered booting issues? My Samsung galaxy tab 2 which I returned was running on 4.04 and froze up on the boot screen. If this is a widespread problem maybe this forum could try and find a solution other than simply returning the device.
    09-03-2012 10:07 AM
  2. still1's Avatar
    I dont think its an ICS/Android issue. you are having an issue but i dont think it exist in all tab 2.
    you might want to hard rest your tab and see if it fix the issue.
    nexusisneecesary likes this.
    09-03-2012 11:13 AM
  3. nexusisneecesary's Avatar
    While I Encountered another person with a almost identical problem who was also running on 4.04 his username is ekmickens so you can view his post and he was using a droid razr. Sorry here's the thread link
    http://forums.androidcentral.com/sho...d.php?t=205773
    09-03-2012 11:18 AM
  4. still1's Avatar
    have you tried hard reset?
    09-03-2012 12:09 PM
  5. rhodest7's Avatar
    Im running ics 4.0.4 and have had no issues hope you get it figured out
    Sent from my GT-P3113 using Android Central Forums
    09-03-2012 12:16 PM
  6. nexusisneecesary's Avatar
    Yes it didn't work sent it back and getting a refund that way I'm not paying for two tablets. I would keep trying to fix it but can't afford the payments
    09-03-2012 12:38 PM
  7. still1's Avatar
    is there a rest utility available for samsung tab 2. I know kies can reset samsung phones but not sure if its for tab 2.
    try downloading kies from samsung and give it a total restore.
    09-03-2012 01:50 PM
  8. tallsc's Avatar
    09-05-2012 02:08 PM
