1. Irvgotti's Avatar
    I can watch videos on my iPad using chrome but when I use my nexus 7 I can't. Says I need flash player :! Just wondering why I can't on one but can on the other'
    09-03-2012 05:02 PM
  2. chubb's Avatar
    If you can watch something on the ipad, you should be able to watch it with chrome. As you may know flash is dead now. You can sideload the flash apk, but can't dl it off the play store anymore. Only thing I can think of, is if your not on the mobile version of the site. Both chrome and i anything are using HTML5 now.
    09-03-2012 05:07 PM
  3. Irvgotti's Avatar
    Yeah I know all that. But it was weird I loaded the same page. (Both in desktop) and it would only play on the iPad
    09-03-2012 09:50 PM
  4. EvilMonkey's Avatar
    Yeah, I've had the same problem. For some reason, videos using Chrome on my iPad (2) are defaulting over to the HTML5 version (so the video plays), but on Android Chrome on my Galaxy S3, it tries to play the Flash version (which Chrome doesn't support).
    I haven't figured out how to get Android Chrome to request the HTML5 version like the iPad is. It's annoying, so I've resorted back to Dolphin HD for those sites.
    09-04-2012 09:34 AM
  5. Irvgotti's Avatar
    Yeah. I went back to the "browser" but I thought that was weird
    09-04-2012 05:34 PM
