1. thesoundunion's Avatar
    Ok i have a synet7lp-ds tablet it came with stock 2.2 firmware here is my issue for some reason the device is not seeing the internal storage it says it has zero and the 2.2 update disabled the ability to mount an sd card in this specific tablet plus it dosent have any app store anyway. So if anyone knows how to fix the internal storage issue or has a copy of the 2.2 stock rom for this device it would be appreciated and its not the synet7lp firmware ive seen posted everywhere its the synet7lp-DS Thanx
    09-05-2012 09:22 AM
