1. flawlis101's Avatar
    How are you doing android central im new here and need serious help on flashing my samsung S2... I have searched high & low for a guide, tutorial. anything that actually works for my situation. I already have a existing acct with boost mobile witch is where im trying to flash2.. i found a tutorial on youtube that directed me to download a bunch of stuff that just didint work ie.. cdma workshop 2.7... plz im dying here need help..
    09-05-2012 01:20 PM
  2. lethalgorman's Avatar
    Don't know if this will help, but I found a site that is great for SGS2 devises. It's think it's called "rootsgs2.com". Try Googling that. That site has step by step. And videos. I use to flash and root alot.
    Sent from my SGH-T989 using Android Central Forums
    09-05-2012 03:32 PM
  3. Devinator's Avatar
    Welcome to AC!!
    Have you tried checking in the S II forums to see if there is a guide for rooting? If not, try doing a search if you haven't already. Good luck!!
    09-06-2012 09:05 AM
