I was thinking I would only by a nexus phone. I Love to root and use custom ROMs...so timely updates are never a problem. So, is it really worth getting a nexus? I feel like just getting a phone with beefed up specs and running cm10 or aokp will be good or even better. Unless the next nexus has incredible hardware. Which I believe it will since there is no reason to release another version of android. So what about you guys? Are you staying with a nexus or getting a different device and use a custom ROM.?
