1. gfsolutions's Avatar
    This a wierd one. I have a GT-I5800 running Froyo. If I try to make, or receive calls, the microphone does not work (i.e. the other person cannot hear what I am saying). However, if I turn speaker phone on, then they can hear me! This leads me to believe its a software, rather than hardware issue.
    I have tried, without luck, to search for a solution to this, and have even considered a custom ROM, but have no idea as to which one would be best,
    I have also performed a factory reset to see if that would fix things, but it didn't (although I do have a much tidier phone now!).
    Does anyone have any solutions/suggestions to this? If it involves a custom ROM, then that's fine (although I haven't ever done that before, so a step by step would be very helpful!).
    It is very frustrating, epecially as my wife's phone (same make, model, firmware), is working with issue!
    Thanks.
    09-11-2012 03:04 PM
  2. Devinator's Avatar
    If a factory reset didn't work, I would think that it was hardware. Have you contacted your manufacturer?
    09-12-2012 09:52 AM
  1. microphone not working with headphones
    By pcbtmr in forum Verizon HTC Thunderbolt
    Last Post: 01-02-2019, 08:09 PM
  2. Bottom buttons not working but touch screen is fine
    By celliott707 in forum HTC EVO 4G
    Last Post: 08-04-2017, 01:17 PM
  3. PLEASE HELP! Skyraider - password unlock suddenly not working! password won't unlock!
    By vtvette in forum Incredible Rooting, ROMs, and Hacks
    Last Post: 12-29-2010, 03:18 AM
  4. help me please! ROM Manager not working correctly!
    By J_HaX in forum Motorola Backflip
    Last Post: 12-17-2010, 01:14 AM
  5. (help) in u.k. Voice not working
    By anneoneamouse in forum AT&T Captivate
    Last Post: 08-26-2010, 06:36 AM
