I have recently got an ICS update on my Motorola Atrix 2 in India. I have been using gingerbread for quiet a long and now suddenly everything has changed.
I have anyway explored almost all the changes in ICS. But I am still not able to find one feature which I really loved in gingerbread.
When I press and hold on empty part of home screen, a pop up comes up listing widgets, shortcuts, folders and wallpaper which is now replaced by wallpaper only. However, widgets can be still added after pressing menu key and selecting widgets tab. Folders can created by just dragging and dropping apps on one another.
But the most shocking part for me is that there is no way I can create a shortcut or at least I didn't find. I had pinned "catch" notes on my home screen in gingerbread which is not working anymore although the option is still there in the catch application.
Using Astro File Manager, I used to create my important folders from sd card as shortcuts on my home screen which is also not working any more. Please help me. Is there anything I am missing out or ICS for motorola atrix 2 doesn't have that feature?
