1. ansa82's Avatar
    So when I look at battery function under settings, it lists my screen as using 64% of battery. is there anyway to get this down?
    Sent from my VS950 4G using Android Central Forums
    09-23-2012 03:49 PM
  2. MangoPowah's Avatar
    Pretty much the only way to do that is to not use your phone. /sarcasm
    Yup, low screen timeouts are one of the best ways.
    Sent from my HTC One X
    09-23-2012 03:49 PM
  3. B. Diddy's Avatar
    Set the screen brightness to as low as you can tolerate. Also, if you're accustomed to keeping the screen on when you're not using the phone, then set the screen timeout to a short amount of time.
    09-23-2012 04:17 PM
  4. ansa82's Avatar
    K thanks!
    09-23-2012 07:40 PM
  5. anon(847090)'s Avatar
    man i laughed at this comment.
    @OP the only way I know is to reduce the screen brightness and reduce the screen timeout period.
    ChromeJob and kkapoorr like this.
    09-23-2012 10:22 PM
  6. Mooncatt's Avatar
    Can also plug the phone in during extended use.
    09-24-2012 09:44 AM
  7. kkapoorr's Avatar
    Naa, could heat up the device
    Author Of NoobTech
    http://wp.me/2uu9r
    09-24-2012 10:27 AM
  8. jean15paul's Avatar
    B.Diddy is correct with these 2 suggestions. There's one more thing I could recommend. If you have a phone with a AMOLED display then use a wallpaper with a lot of black or very dark colors. When displaying black on an AMOLED display the black pixels actually turn off which can save on battery (it also results in "blacker" blacks). Unfortunately this doesn't work with LCD displays because they display black with the pixels on, which is also why blacks don't look as good on LCD displays.
    I don't know what kind of display your phone has. (And I'm too lazy to look it up at the moment.)
    B. Diddy and jbookworm1 like this.
    09-24-2012 01:47 PM
  9. ansa82's Avatar
    I have the big ol LG Intuition so I'm sure thats why my screen is using up so much battery... Its so big! I really like the device though.
    09-24-2012 08:17 PM
  10. Rukbat's Avatar
    No matter how long your screen timeout is, you can always turn the screen off as soon as you're finished using it. Just tap the power button.
    09-25-2012 12:14 AM
  11. ansa82's Avatar
    I've started doing that too
    09-25-2012 05:34 PM
  1. How to get a: White or Red Battery Cover for your Incredible
    By BetaRoc in forum Incredible Accessories
    Last Post: 01-26-2011, 11:41 PM
  2. Replies: 2
    Last Post: 10-08-2010, 08:38 AM
  3. How to get a: White or Red Battery Cover for your Incredible
    By BetaRoc in forum Verizon Droid Incredible
    Last Post: 09-05-2010, 10:56 AM
  4. What uses less battery: connected to 3g or 4g?
    By dvdqnoc in forum Sprint Epic 4G
    Last Post: 09-02-2010, 11:01 AM
  5. How to get ringtones and use them
    By BabyGirl230 in forum General Help and How To
    Last Post: 08-30-2010, 06:07 PM
