1. waxwabbit's Avatar
    Hello everyone
    Newbie here.
    Im looking at buying a tablet. Undecided about 7 or 10 inch. Was looking in the shop.....
    I have to get it within 1 week or so.
    I like the nexus - however I must be able to get hold of the RIO movie (for my daughter). I couldnt find it on google play. Would I be able to buy it elsewhere (say amazon), and store it on either 8gb/16gb versions?
    I'm after a good skype version for the tablets too - I am not seeing much info for the nexus and this??? Anyone tried?
    These are my main lines of queries........
    So to summarise :
    Use it for Rio movie
    Skype
    General web browsing
    Thanks for reading
    I greatly appreciate any feedback
    L
    10-07-2012 09:25 PM
  2. anon(847090)'s Avatar
    Hello everyone
    Skype
    There should be a way to buy the Rio movie and use it in Nexus. i would let others answer this
    skype official app is available in google play store and it works well https://play.google.com/store/apps/d...m.skype.raider
    Nexus 7 is really good for general browsing due to its portablility. I higly recommend going 7inch and Nexus.
    waxwabbit likes this.
    10-08-2012 12:16 AM
  3. waxwabbit's Avatar
    Ive seen its on Itunes.........I have a digital copy (CD/Dvd), so I am not sure........
    Maybe I should just buy a portable dvd player, and a nexus
    We are going on a 7 hr flight - and my daughter is 1.......so u see my desperation for answers lol
    cheers
    10-08-2012 02:07 PM
  4. anon(847090)'s Avatar
    cheers
    If you have a DVD/CD of the movie. simply rip the movie and transfer it to your Nexus 7.
    use MX player app to play all kind of movies. https://play.google.com/store/apps/d...videoplayer.ad
    10-08-2012 02:16 PM
  5. waxwabbit's Avatar
    thanks.......
    does the nexus have a usb cord? I didnt think to note what connections it has when i was in the shop.
    10-08-2012 02:52 PM
  6. anon(847090)'s Avatar
    thanks.......
    Yes, the charger cable can be used as usb cord. look at this image then you will understand https://play.google.com/store/device..._charger&hl=en
    10-08-2012 03:07 PM
  7. waxwabbit's Avatar
    Ok everyone
    Im getting a little frustrated trying to put the film on the n7..........
    I have ripped the digital copy to my pc
    I have hooked up the usb to the n7
    I have MX Player on my n7
    When I drag the wmv file to the n7, it says it can not do it because the license does not allow it
    Is this DRM?
    So I downloaded pavtube........
    I have format set as N7 H.264 video (mp4)
    Output is a user file on my pc
    The added file is RIO wmv...destination file says RIO
    I just tried starting it.......it was saying 2 hrs.......does that sound right?
    any other pointers?
    I appreciate any input
    10-13-2012 01:13 PM
  8. waxwabbit's Avatar
    Anybody please?
    10-14-2012 04:07 PM
  9. Rukbat's Avatar
    2 hours to encode a movie? Could be - it depends on the speed of the computer and the algorithm the program uses. Let it run. (It should be finished or almost finished by now.)
    10-14-2012 06:26 PM
  1. Help, Help, and more Help
    By The Duck in forum Samsung Galaxy S3
    Last Post: 07-24-2012, 04:58 PM
  2. Help and advice needed please
    By lisavye in forum General Help and How To
    Last Post: 12-29-2011, 12:25 PM
  3. Have Optimus S, and also now Tablet...help with apps please!!
    By gilbequick in forum LG Optimus S Rooting, ROMs, and Hacks
    Last Post: 12-28-2011, 07:37 PM
  4. Lost contacts and apps! Please help ASAP!
    By justmetoo1 in forum General Help and How To
    Last Post: 09-02-2011, 07:24 AM
  5. problem with apps and display?...help
    By Kamran1981 in forum Motorola Droid
    Last Post: 01-17-2010, 05:17 PM
