Hello there,
today a strange icon started to show up in the notification area. It has no notification attached to it, restarting the device doesn't make it go away and neither am I aware of any app installed that could have caused this. Due to the resemblance the icon bears to the ICS logo, I thought it might be some system-based event (something like an android anniversary date or whatnot), yet it persisted through GMT midnight, which makes it seems less likely then it did when I found out. I tried an image-based search for any images and screenshots containing the said icon, but came out empty-handed. Do you have any clues / ideas as to what the cause could be?
EDIT: Problem solved!
As Henzman said, it's the new icon of the Power Toggles app.
