Devinator
Sūpā Saiya-jin Fō
In the mean time, there are other options available to uninstall bloat. Just google it and you'll find some apps that will do it. I think the best way to do it probably, is to freeze them, with something like Titanium Backup, then use the phone for a while, if nothing goes wrong after a couple of days, you can remove them.
