Has anyone experienced this or is there something in the ROM that can be tweaked to overcome this:
Device info: HTC Inspire 4G - CM10 custom (unofficial) ROM
Having an issue with the Amazon Appstore on one specific device with a custom Jelly Bean ROM. The Amazon Appstore won't stay signed in. Once I sign in, if I remove the store from "Recent Apps" or if I reboot my phone, the Appstore app won't be signed in. Worse than that, whenever I re-sign back in, it re-registers it as a completely new device. I have to go to the Amazon website and deregister all the instances of this one particular device. That doesn't help with anything, though. The Appstore on this particular device will keep signing out upon app close or reboot and keep making a new device register whenever I re-sign back into the Appstore.
I've searched and searched and have tried many things with Titanium Backup and Root Explorer - like setting permissions and special permissions - but nothing helps. I've uninstalled and reinstalled. I've used different versions of the Appstore. Nothing helps. It's only on this one device with this one particular custom ROM. The Appstore on all of my other devices works perfectly normal, no issues at all. And some of them have a custom ROM. And on this particular device with the issue, I can flash another ROM and the issue is gone. I want to keep this ROM, though, because it's the smoothest and best functioning ROM yet. It just won't let the Appstore stay signed in. And the Appstore is the only app that has this problem. None of the many other apps on this device - that require a sign in - don't lose their sign in information, only the Appstore loses it.
