Hey,
I got a really bad problem. My Samsung GS3 won't connect to my Uni's wifi. It connects to every other wifi, except my Uni's. This is a problem because I'm on low Mobile Data allowance, and that's because I didn't know my phone wouldn't be able to connect to my Uni's wifi...
And it's something wrong with mine (which is specifically a 4g/lte), since my friend has a Samsung GS3, and that connects fine.
Anyways, I think it has something to do with the 802.1x EAP wifi's... when I try to connect, it just keeps saying connecting and sometimes ends up "Authorization error".
Here's some screenshots;
Would appreciate any possible solutions to try.
Thanks.
Thanks.
