Help! My Galaxy Tab might be bricked
scratch135
6
I have my daughter's galaxy tab that seems to be bricked. its a SPH-P100 (Sprint).
my son was fooling around with it and left it in the following state:ys the following:
Android system recovery <3e>
Enter: OK Key, Select : Vol Up / Vol Down
reboot system now
apply update from sdcard
wipe data/factory reset
wipe cache partition
_____________________________________________________________________
-- bootmode=7 from cmdline...
E:failed to mount /cache (No such file or directory)
E: Can't mount /cache/recovery/command
-- Wiping data...
Formatting /data...
E:format_volume: rfs format failed on /dev/block/mmcblk0p2
Formatting /dbdata...
E:format_volume: rfs format failed on /dev/block/stl10
Formatting /cache...
E:format_volume: rfs format failed on /dev/block/mmcblk0p1
Data wipe failed.
E:Can't mount /cache/recovery/recovery_kernel_log
E:copy_kernel_file :: Can't open /cache/recovery/recovery_kernel_log
E:Can't mount /cache/recovery/log
E:Can't open /cache/recovery/log
E:failed to mount /cache (no such file or directory)
E:Can't mount /cache/recovery/last_log
E:Can't open /cache/recovery/last_log
Can anyone help me to fix this? or is it just an electronic paperweight now?
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,601
4,741
113
I don't think the OP has the ability to select the reboot option. His post looks like a screen dump showing the aftermath of doing something bad in the recovery menu. Unfortunately, I don't have any good suggestions.
scratch135
6
Still1 I think that everythis has been deleted except the samsung spash screen.
Fairclough, thank you for the link, I will check it out and hope it will solve my problem
Devinator I most definately will post a solution if I find one, thank you.
lshodges
Im having the same exact problem all I did was play Candy Crush turned it off that night woke up and rhe Galaxy Tab was bricked as you put it..:( E:Can't mount /cache/recovery/log
E:Failed to mount /cache (No such file or directory)
E:Can'y open /cache/recovery/last_log
lindagibney
