Help - I deleted the clock on my Nexus 4
p1neapples
13
I am an iPhone 5 convert with a new Nexus 4. I somehow in trying to learn things have deleted the stock clock app when i was only try to remove the home screen widget. How can I get the clock back?
anon(847090)
6,655
31
It is not in the App Drawer, so entirely...:(
you cant delete a clock app unless you are rooted. do you mean you deleted it from home screen or app drawer?
if its from home screen click the 6 dots on the centre and search for clock and touch and hold
or you might have disabled it. go to settings-->Apps-->All Apps-->[scroll all the way down]-->see if you have clock app there-->select it and click enable
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,594
4,737
113
In the App Drawer, make sure you're looking in the Widgets section. Tap Widgets at the top of the screen after bringing up the drawer.
samyblaze
