1. tucsonstan's Avatar
    Having an EVO, how do I change or mute the annoying start-up sound whenever I power the unit up? My cats head for the hills every time they hear it. Thanks very much.
    07-24-2010 10:19 PM
  2. meyerweb#CB's Avatar
    The easiest way is to make sure you turn the ringer volume all the way down before powering the phone down.
    If your phone is rooted, there's a more complicated way to fix it permanently:
    [HowTo] Disable HTC Evo 4G Startup Sound - Android Forums
    07-24-2010 10:33 PM
