I have a PPTP VPN connection that I use from time to time to access files on my Windows server at work when I am at home on my laptop or on another computer. It works great... I just map the drive in windows and bingo, my files are there.
So, I was excited when I set my VPN connection up on my Samsung Captivate (it is rooted, if it matters). I set everything up, and it connected on the first try. I sat there and looked at the screen and thought, "okay, what do I do now?"
Perhaps I am missing the boat on this whole VPN for Android thing, but is there a way to access the files on a VPN server? I have the ability to map the drives on a PC, but I can not find a spot to do it on the Android.
