got an s3 in jan and it has it has worked perfectly until today when i plugged in my headphones i could only get sound from one cup
i changed headphones same problem and i tried the headphones with other devices they were fine is there anything i can do sound from only the left headphone same with earphones the problem can be rectified by pushing the connecting jack down and to the left or pointi
ng it a certain way but it goes back to one earphone if you leave it and so i want a more permanent fix if i can get one
