08-13-2017 03:13 AM
51 123
tools
  1. desklamp_five's Avatar
    I tried all of the methods listed here but without success. However I have found something that works.
    1: install File Manager + (by Flashlight)
    2: install Advanced Task Manager (by Infolife)
    3: Go into the ATM Settings, then add all of your apps to the Ignore List, EXCEPT File Manager +
    4: Place the ATM widget right next to the FM+ app on your Homescreen.
    File Manager + will happily copy files onto external usb drives and SD cards, but ONLY one time, after booting up. So each time you copy or move a file to a usb stick just remember to press the ATM widget when you've finished. This will Force Stop FM+. Then it's all ready to do it again next time.
    08-13-2017 03:13 AM
51 123
  1. Will Gear Live connect to Galaxy S5's S-Health app?
    By FaintDeftone in forum Samsung Gear Live
    Last Post: 01-15-2015, 09:02 PM
  2. Disappearing Apps That Can't Be Reinstalled
    By karebo in forum Ask a Question
    Last Post: 09-19-2014, 02:10 PM
  3. wifi connection is not working. please help
    By Mat Bice in forum Verizon Samsung Galaxy S4
    Last Post: 09-19-2014, 01:53 PM
  4. Force phone to 3G?
    By vbeltran in forum Verizon Samsung Galaxy Note 3
    Last Post: 09-19-2014, 11:43 AM
  5. Replies: 0
    Last Post: 09-19-2014, 11:19 AM
