So I travel a bit, and use my tablet on the plane to watch movies.
I transferred some movies to my tablet via the external SD Card, watched them, then deleted them.
But the Google Play TV & Movies app still lists them as being there. Try and play them, and it says they can't be played (not surprising since they aren't on the tablet anymore). Neither DoubleTwist nor MX Player list them, but do pick up the current movies that I have on my SD Card. Play T&M list the new ones as well ... but still list the old ones (I'm attaching a pic of the old ones listed in the app, sorry for the glare)
Where does the system store the list for Play TV & Movies? I've rooted my tablet, uninstalled the Play app ... then reinstalled it from the Play store and it STILL shows the old movie links. So I'm guessing that somewhere on the tablet is a file that contains the list I just don't know where that is. I've cleared the cache, cleared the data ... nothing helps.
Thanks!
ICS 4.0.4
Thanks!
ICS 4.0.4
