ROMs??
MrCGym
Active member
Apr 29, 2013
39
I will be switching from iPhone 4S to either HTC One or GS4 next week.
I am interested in uploading a ROM. I've been reading a bit about them and believe Chameleon may be the best idea. I'm wondering what others think and how I go about getting/using it.
meyerweb#CB
Banned
Sep 4, 2009
6,668
5
You should probably ask about this in the specific phone forums.
ROMs are very device specific. Flashing a ROM intended for a different device, even the same device on a different carrier, will turn your phone into a very expensive door stop. This is commonly referred to as "bricking" your phone. I'm positive there are not yet any custom ROMs for either of these phones. It will take developers time to study the source code, modify it, and test and produce stable, custom ROMs.
In order to "flash" a custom ROM, you first need to "root" your phone. While you are waiting for custom ROMs and root processes to become available, read through the rooting forums for other recent htc and Samsung devices on your carrier. Things should be similar (but not identical) for the One and S4 once custom ROMs are available you'll be much more knowledgeable. Also read through the blog posts on A|C. You'll find explanations of what rooting is all about, and explanations of a lot of the terminology you'll encounter in the rooting forums.
Finally, be aware that rooting will almost certainly void your warranty, and if something goes wrong during the root process, or while flashing a ROM, that you can't recover from, neither the manufacturers nor carriers will have any sympathy. Be very sure you understand what you're doing before even thinking about doing this.
Now then, why do you want to flash a custom ROM? What do you expect it to do for you? Most of the things you need to jailbreak and iPhone to do, you can do on a stock, unrooted Android phone.
EvilMonkey
1,808
103
If you're just coming from iOS, I'd highly recommend just using the phone as-is for awhile before you leap face-first into custom ROMs. Maybe you'd share why you want to flash another ROM right away?
Just getting used to Android will be a bit of a learning curve and adjustment without having to deal with the nuances of a different ROM, and you might be surprised by how customizable the phone is out of the box without jumping to another ROM.
I personally would just spend some time finding the right keyboard for you, the right apps, etc and then maybe play around with maybe some different launchers and stuff.
Just my two cents, is that I'd use the phone for awhile before diving off the deep end and root and flash a ROM.
WillyC
