1. Jonathan Goldman's Avatar
    I bought a Cobalt SP300 on eBay and one of its faults is that the power button on top is a little shallow and hard to push...unfortunately it's the only way to wake the screen. I really want to use the volume keys to wake up the screen. I've tried a button remapper app (didn't work correctly) and tried an app called No Lock which disables the lock screen and allows you to wake the screen with the volume keys. The problem with it is that it only works like 10% of the time and I like the lock screen as well.
    I think my only other option at this point is to manually try to edit the files. I found out how to root my phone and then through root explorer went to system/usr/keylayout and there is a file I think maps the buttons: mt6575-kpd.kl
    I find
    key 115 VOLUME_UP WAKE_DROPPED
    key 114 VOLUME_DOWN WAKE_DROPPED
    key 113 MUTE WAKE_DROPPED
    key 112 POWER WAKE
    So I see the volume keys say WAKE_DROPPED instead of just wake. According to a search I did by what the dropped part means, it should still wake the screen but it doesn't. Would it be sensible to edit these to only wake? Do I chance bricking my phone doing this? I tried to backup my phone using MTKDroidTools but I can't get the backup function to work...
    04-29-2013 11:32 PM
  2. kslakhani's Avatar
    hi,
    I am also having mtk6589 based device
    tried already not working
    did u managed then???
    10-06-2013 06:02 AM
  3. srkmagnus's Avatar
    If you mess up the button remapping you could make this issue worse, so I wouldn't suggest that. If you can root you can install a custom ROM that allows you to use the volume rockers to wake the device. I'm not sure that there is any other way to do it.
    Sent from my GT-P7510 using AC Forums mobile app
    Golfdriver97 likes this.
    10-06-2013 12:28 PM
  4. Golfdriver97's Avatar
    Magnus has a much better idea than remapping. I have come across a couple threads where remapping messes the phone up.
    From a Sprint Moto X using AC forums app
    10-06-2013 01:31 PM
  5. B. Diddy's Avatar
    You could try this app, which doesn't seem to require root.
    https://play.google.com/store/apps/d...rezenk.wakeall
    10-06-2013 05:21 PM
  1. any way to keep the screen off when I get an SMS?
    By No1up in forum AT&T Galaxy S III
    Last Post: 08-21-2012, 11:58 PM
  2. Using a gesture to wake the screen?
    By dosbox in forum General Help and How To
    Last Post: 04-16-2011, 01:56 PM
  3. Optical pad to wake the phone?
    By solideliquid in forum Verizon Droid Incredible
    Last Post: 05-31-2010, 08:57 AM
  4. Anyway to make the screen slicker?
    By ThirstyTurtle in forum Motorola Droid
    Last Post: 12-21-2009, 12:24 PM
  5. Replies: 2
    Last Post: 11-16-2009, 01:22 PM
