1. mrcoyote's Avatar
    Just made the switch from the BB storm to the HTC Desire and have some newbie questions...
    1) how do I _not_ have to unlock the phone 3 times before I can use it?
    - currently I hit the power button to turn the screen on, then swipe down, then use the pattern unlock.
    If I could get rid of the swipe down part, that would be ok.
    2) do I need a screen protector on this thing? The storm was a glass screen, so pretty much impossible to scratch.
    any other advice??
    I'm sure some searching will answer my other questions, but for anyone with time on their hands:
    1) what's a good todo app?
    2) what's a good memo/note app? (ideally with a way to backup my info - online or other)
    3) ebook reader that will read the PRC files I made with mobipocket
    4) good newsreader (like viigo)
    thanks!!
    08-10-2010 01:21 PM
  2. cloak.n.dagger's Avatar
    You can turn the lock pattern off in the security settings. I have read about an app called No Lock that others have said works well...
    No Lock - Android app on AppBrain
    08-10-2010 04:49 PM
