Hi Guys,
Long time reader first time poster of this site.
I have an issue with being able to send files via Wifi Direct between my S4 and my mates HTC one. I can use my wifi Direct between other s4's and s3s but it the problem I am getting with HTC one is a little strange.
It connects fine but when I try and send it fails. I also tried installing superbeam and getting the exact same problem. We both have NFC enabled, I have tried enabling S beam, I have turned off NFC on both devices and it still doesn't work.
My friend with the HTC one can connect to normal wifi and also can connect to my phone when I turn it into a hot spot.
I would be grateful for any advice you guys can offer.
Kind Regards,
Parm
Kind Regards,
Parm
