how to get a brightness slider on notification?
Johny Ramos
Hi guys I've been looking like crazy for a way to get an always present brightness slider on the notification bar of my Htc one x
just as the one on touchwiz for s3 and s4. but without rooting!
would be great to find some help here!
Golfdriver97
Trusted Member Team Leader
Moderator
Dec 4, 2012
35,367
113
63
Have you tried looking on Play for a widget? The downside to what you are asking is, that is something that is integrated into the ROM.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,594
4,736
113
Try Power Toggles. You can't put a slider directly in the notification widget, but you can put a quick shortcut there. So you would swipe down, tap the slider shortcut, and the brightness slider pops up immediately.
Sizzers
637
54
28
You can overlay a slider on the status bar with Display Brightness If I remember correctly that's with the free version as well.
wei34
