I noticed the battery on my Droid Bionic has swollen, and I know I need to replace it. I was looking into things and noticed that while my factory battery is listed on the back to be rated for 3.8V, my battery monitor app is reporting 4.338V. I know that's not good and subsequently have to run it down to 80% to get to 3.8V, but also sometimes seeing the voltage rise a bit here and there despite not on the charger.
So my question is what causes the battery voltage to get up so high? Is it indicating a bad charger (even though USB its rated about 5V already), something wrong in the phone, or just a side effect of the battery going bad for other reasons (i.e. Getting too hot)? The only info I've found so far just says standard Li-on cells are not good above about 4.2V, but nothing on potential causes in phone use. Thinking of getting an extended battery, but don't want to spend the extra money if I have to worry about it getting a high voltage charge too.
