1. zzzbbb's Avatar
    i have a Samsung galaxy ace, i just went on the weather and news app that is already installed on the phone when you buy it. the weather location has been changed to a village in my city... and I never changed it and i'm just thinking is it possible I could have been hacked?! I don't know how or why it changed, nothing else seems to be wrong with the phone though... I have taken all my pictures off just in case but can someone please reassure me as to why or if any of you guys have had the same problem.
    thank you
    edit:
    it's just gone back to normal now :s
    can someone tell me why this happened please, really confused.
    06-28-2013 10:02 AM
  2. VDub2174's Avatar
    How wrong is the city? Is it close?
    Some weather apps don't pick up my exact city so it defaults to the next closest city.
    06-28-2013 10:40 AM
  3. zzzbbb's Avatar
    it was a village in my city. the app had been fine, I just went on it to check the weather and found that it said something else, do you think after an update it may have changed? :s, i'm not 100% sure if that particular app updated, but I do know that a couple did, it seems to have gone back to normal now though, but I don't know why it happened in the first place
    06-28-2013 10:45 AM
  4. garublador's Avatar
    Is your app set to use your current location? It sounds like it just didn't quite get your location perfect.
    06-28-2013 12:51 PM
  5. Jarnld's Avatar
    If it uses network location versus gps its going to be kinda off. You're okay.
    06-29-2013 01:51 AM
  6. bobbyl97's Avatar
    You didn't get hacked or anything, its ok. This happens all the time. The GPS isn't perfect. I get my phone giving me the next city over all the time.
    06-29-2013 10:49 PM
  1. Can't access screen during incoming calls
    By Mike Wachholz in forum Verizon Samsung Galaxy S4
    Last Post: 09-05-2013, 08:44 AM
  2. Confused! Please Help
    By Ra222r in forum Samsung Galaxy S4
    Last Post: 06-30-2013, 11:14 PM
  3. Can someone create this widget?
    By Steven Thomas3 in forum General News & Discussion
    Last Post: 06-28-2013, 09:35 AM
  4. Replies: 0
    Last Post: 06-28-2013, 06:32 AM
