1. PoRco1x's Avatar
    So I registered on this forum using my Facebook ID (firs time I'm using my facebook ID and it's coming to bite me in my ***)
    And now when I try to login to android central via tapatalk it won't give me the option to login via facebook . Do I put in my username and facebook pw? Or...
    06-28-2013 10:10 AM
  2. Christopher Matthews Jr's Avatar
    Go to settings (the little cog symbol next to your username in the top right), and you can see your username.
    After you configure your username, go down to the change password option, and type in, and confirm a password. Then try your login again on tapatalk.
    (I did it this way, and it worked for me)
    (EDIT: This is assuming you're already logged in)
    PoRco1x likes this.
    06-28-2013 10:37 AM
  3. PoRco1x's Avatar
    Oh yeahhh! That worked, thanks a lot Christopher!
    Sent from my HTC One using Tapatalk 4 Beta
    06-28-2013 10:47 AM
  4. Christopher Matthews Jr's Avatar
    No problem! Hope you enjoy the forums!
    06-28-2013 10:52 AM
  1. Replies: 5
    Last Post: 06-28-2013, 02:59 PM
  2. New to Android - and the forum!
    By mwatson2 in forum New to the Forums? Introduce Yourself Here!
    Last Post: 06-28-2013, 01:58 PM
  3. Do you use a spare battery?
    By Razeus in forum Samsung Galaxy S4
    Last Post: 06-28-2013, 10:24 AM
  4. Cannot add Exchange 2010 mailbox to EMAIL options jellybean 4.1.2
    By searcherrr in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 06-28-2013, 09:32 AM
  5. [NEW] Treasures of the Deep. Dive in!
    By Hero Craft in forum Android Games
    Last Post: 06-28-2013, 08:33 AM
