Hi,
I've dipped my toes into the rooting/flashing waters and have been doing some reading for the past 6 days...
I did jump the gun on day 2 and flashed + rooted (strangely in that order, which means I must have rooted my phone ages ago.. and then locked my bootloader after flashing..?)...
I do have Rom manager installed... but I don't quite recall how I ended up flashing the stock rom onto the phone..
Anyways, as I did seem to reset my phone, I upgraded all the apk packs and I'm pretty happy with the speed upgrade + ext2 internal space expansion.
As I now want to create a nandroid backup, so I can always come back to my current status, when I want a clean reinstall..!
My main question is that as I seem to have skipped creating a CWM recovery... if I do so now, will I loose all my data and go back to the basic stock rom?
The problem I'm facing right now is that I'm unable to boot into the recovery mode using either
"adb reboot recovery" or the power on + vol buttons / menu button.
(which means that I don't have the recovery mode installed.....)
So.... will I loose my current upgrades + phone settings (reset into factory mode), if I flash the recovery mode?
