1. thinkican's Avatar
    Hi All,
    I have been trying to find step by step instructions on how to install stock android on my AT&T S4 for the past 30 min...but its complicated. Is there a way a person can install stock android, like installing Windows on a PC?
    Thanks,
    06-30-2013 01:50 AM
  2. Paul627g's Avatar
    Hello,
    Installing stock (AOSP) Android on your S4 is not really as involved as you may think. It only seems very intimidating at first until you understand and learn the processes used to do it. In all honesty if you want to run stock or vanilla (AOSP) Android on your S4 you should take the time to learn the techniques necessary to obtain it. The time will come eventually when you want to change or need to restore to factory stock in the event of repair/warranty, etc and you will have to use these skills again.
    06-30-2013 09:59 AM
  3. srkmagnus's Avatar
    Here is how to root the AT&T S4: http://forums.androidcentral.com/sam...galaxy-s4.html
    Get the CM ROM, which is based off ASOP (or stock Android) here: http://wiki.cyanogenmod.org/w/Jflteatt_Info
    Instructions on how to flash here: http://wiki.cyanogenmod.org/w/Install_CM_for_jflteatt
    Be sure to read up as Paul said. If you have any questions let us know and we'll see how we can help.
    Sent from my SPH-D710 using Tapatalk 2
    06-30-2013 11:50 AM
  1. To Root or Not to Root
    By op t must in forum Virgin Mobile Optimus V
    Last Post: 01-24-2015, 03:34 PM
  2. [ROM][alpha] Victorious -- VM Stock 4.1.2 Deodexed & Optimized
    By JerryScript in forum Samsung Galaxy Victory
    Last Post: 10-21-2013, 12:37 AM
  3. The Android UI Speed Issue (A Theory)
    By WickedRabbit in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 07-01-2013, 01:40 PM
  4. What is the easiest way to unroot the HTC evo design 4g?
    By BGoldsmith in forum HTC EVO Design 4G
    Last Post: 06-30-2013, 01:23 AM
  5. The best word puzzle game in Android
    By nilupul21 in forum Android Games
    Last Post: 06-29-2013, 11:44 PM
