1. icarus130's Avatar
    my Razr Maxx HD has been running awful for the past week, so i decided to do a factory reset, see if it would help. Well, it's now been doing the factory reset for well over an hour. it's on the screen with the android guy and the blue light spinning on his chest and the blue line spinning at the bottom but it won't go any further. I did a factory reset on my phone back in Feb and it took 5 minutes so i know somethings screwed up. suggestions?
    07-03-2013 05:39 PM
  2. srkmagnus's Avatar
    Are you still experiencing the problem? Hopefully you got it to boot without any problems.
    Sent from my SPH-D710 using Tapatalk 2
    07-04-2013 01:52 AM
  3. sharon gabrielle's Avatar
    05-06-2016 11:54 AM
  4. sharon gabrielle's Avatar
    Hello mine is doing the same also I cant download adb sideload file on the pc cus its dumb windows,any help is really appreciated. Its a Lenovo yoga2 B6000-F running kitkat 4.4.2
    05-06-2016 12:01 PM
  1. Replies: 3
    Last Post: 07-25-2013, 11:33 PM
  2. Using GPS in remote areas off the grid
    By Burky in forum Droid RAZR MAXX HD
    Last Post: 07-08-2013, 05:58 PM
  3. Phone shut itself down and now stuck in boot
    By glitchgod in forum AT&T Galaxy S III
    Last Post: 07-05-2013, 10:06 PM
  4. Finding random pictures in a Sd Card folder I didn't create.
    By Anonyous934875983475983475 in forum Samsung Galaxy S3
    Last Post: 07-04-2013, 10:12 AM
  5. bootloop frozen but can get in the recovery and odin
    By glitchgod in forum Samsung Galaxy Note 10.1
    Last Post: 07-03-2013, 06:05 PM
