1. curryb15's Avatar
    Hello Im new here and just got a galaxy s4 which I love. I am now looking for a tablet that I can plug my phone into like a computer so I can manage it. I also have a external hard drive filled with movies that I would like to be able to plug into the tablet and watch movies. What tablets are out there that can provide me with these capabilities?
    07-08-2013 12:01 AM
  2. curryb15's Avatar
    Anyone?
    Sent from my SCH-I545 using Tapatalk 2
    07-08-2013 11:35 AM
  3. anonymous495876038576's Avatar
    The only tablet that you might be able to complete those tasks on would be a Microsoft surface
    Sent from my XT881 using AC Forums mobile app
    07-08-2013 12:00 PM
  4. curryb15's Avatar
    Is there a adapter that I can use to achieve that stuff. I really would like to get the tab 3
    07-08-2013 12:33 PM
  5. srkmagnus's Avatar
    I don't understand the managing part of it. Do you want to manage the various files on the phone? If so, you can easily do this with a file manager app and browse the sdcard from the phone and sort/manage as you need to.
    If you want a tablet so you can access certain files on the phone and make edits then you can do this by syncing the files with a cloud service such as Dropbox and access from any device.
    07-08-2013 12:46 PM
  6. curryb15's Avatar
    What about watching movies off a hard drive
    07-08-2013 01:09 PM
  7. srkmagnus's Avatar
    There is a way to connect a mass storage device to Android phones but the phone must be rooted. Here is one such app that allows you to connect a mass storage device to a rooted device: https://play.google.com/store/apps/d...wudXNib3RnIl0.
    I looked through that apps FAQ page and don't see the GS4 as a compatible device. This means that the list of compatible devices has not been updated or the GS4 can't use the app to connect a storage device. In short, there is no way to connect a hard drive or memory stick to a device without rooting. Your best bet is to get expandable memory and keep that in the device with files you may need or want to access. Yes, it's a hassle to transfer files periodically, but is the only way to have increased storage on the go.
    07-08-2013 02:01 PM
  8. curryb15's Avatar
    Right but what I want to do is to be able to plug in my external harddrive and watch movies on that harddrive via my tablet.
    07-08-2013 03:10 PM
  9. srkmagnus's Avatar
    Ah, Ok. Well, you'll need to be rooted and have a compatible device. Look at the link I provided for further information.
    Sent from my SPH-D710 using Tapatalk 2
    07-08-2013 10:47 PM
  1. Detailed Review of all Three new Galaxy Tab 3s
    By tabletrus in forum Samsung Galaxy Tab
    Last Post: 07-11-2013, 08:33 PM
  2. Two problems with my Transformer 700 and one question
    By MrMLK in forum ASUS Transformer Pad Infinity 700
    Last Post: 07-10-2013, 08:52 AM
  3. Replies: 7
    Last Post: 07-08-2013, 05:05 PM
  4. Issues with Instagram
    By MBM7881 in forum Verizon Samsung Galaxy S4
    Last Post: 07-07-2013, 07:29 PM
  5. Replies: 0
    Last Post: 07-07-2013, 05:21 PM
