Customized Samsung Droid Tablet ?
So my wife got a tablet for a specific purpose which is to use it as a portable gallery showing pictures and videos.
She wants files to be located on device so no connection needed to view.
She wants a custom background screen and then different buttons for each Gallery category. User opens per normal and then can scroll through pictures.
If video then thumbnails/list of available videos for user to choose from.
New to Android and not sure how to go about getting this done.
Re: Customized Samsung Droid Tablet ?
Sad - not even 1 reply.
So I have tried using the "Picture Frame" widget.
This would work perfectly if I could set the order of the pictures. I have tried file name (001.jpg 002.jpg 003.jpg) I have tried "the order in which I upload"
And neither will set the order of which it list/shows pictures.
I have tired searching for the developer to no avail.
So does anyone know of an app or widget that will allow me to do what Picture Frame does but allow NOT TO SCROLL and SORT ORDER?
