Moving widgets/shortcuts between panels
Is there a way to move a widget/shortcut that you've installed on the home panel to another panel without deleting and reinstalling? I've tried long press and drag but that only moves it to the edge of the panel its on.
Tried a search for this but didn't see anything (or use the right keywords).
