1. adriandb's Avatar
    I recently installed Battery Widget and love the battery percentage icon it places in the top bar. The only problem is that I have another app that has already put one there and I want to get rid of it. Anyone know what app has placed the left-most battery icon there or know an easy way to figure this out? Thanks.
    07-11-2013 01:12 PM
  2. B. Diddy's Avatar
    Could be related to your clock widget or your toggle widget (assuming they're different).
    adriandb likes this.
    07-11-2013 03:03 PM
  3. Michael Vieux's Avatar
    Is it related to a setting on your phone?
    My S3 has a check box in settings, to show battery percentage.
    Sent from my SCH-I535 using AC Forums mobile app
    07-11-2013 03:50 PM
  4. adriandb's Avatar
    Thank you both for the input. It isn't related to the widgets for sure, because I can turn that one odd and add a third battery percentage to the status bar
    It isn't part of the battery settings on my HTC One that I can tell.
    I don't think it's part of Nova launcher as I can't find a setting for it. Any other ideas?
    07-11-2013 07:42 PM
  5. Michael Vieux's Avatar
    It's not in the battery settings on my S3,its in Display settings.
    Of course we're talking about 2 different manufacturer's.
    07-11-2013 08:36 PM
  6. adriandb's Avatar
    Yeah I don't have anything in the display settings either. Hmmm.
    Sent from my HTC One using Tapatalk 4 Beta
    07-11-2013 10:22 PM
  7. Michael Vieux's Avatar
    Well, it was worth mentioning.
    Sorry it didn't help.
    07-12-2013 09:43 AM
  8. adriandb's Avatar
    I appreciate it. The other thing I want to try is disabling a few apps without removing them from my device. Is this what is called "freezing" an app in the Android world? If not, how would I go about disabling an app without removing it or resetting all the settings?
    07-12-2013 09:51 AM
  9. Michael Vieux's Avatar
    Yes, system apps can be disabled in settings.
    3rd party apps require a standalone app like Titanium Backup.
    I've never used Titanium, but it gets rave reviews in the forums I read.
    Sent from my M470BSA
    07-12-2013 11:26 AM
  10. adriandb's Avatar
    I have Titanuim installed. I'll give that a try. Thanks.
    07-12-2013 12:03 PM
  11. adriandb's Avatar
    I've frozen everything I can think of and still nothing takes it away. Truly frustrating. Thanks for the assistance.
    07-12-2013 12:26 PM
  12. sropedia's Avatar
    If you pull down the status bar is there an ongoing notification for that icon? If so then you can press and hold on it, then hit "app info" and freeze it from there
    Sent from my Nexus 4 using Tapatalk 4 Beta
    07-12-2013 12:56 PM
  13. adriandb's Avatar
    It was Widgetsoid an app I was using to add toggles to my notifications shade.
    B. Diddy likes this.
    07-15-2013 12:26 PM
  14. B. Diddy's Avatar
    Makes sense--Widgetsoid is similar to Power Toggles, which also gives the option to have a battery meter in the notification bar. Thanks for following up--I wish more people would do so, because it's very helpful for other people who may have the same question. And it also helps us, the Ambassadors, because the we can file this away in our memory banks and look like geniuses when someone else has a similar question!
    07-15-2013 10:01 PM
  15. adriandb's Avatar
    Yeah no problem, I hate it when I land on a thread that asks the same question I'm going to and no one ever posted the solution.
    I ended up looking up some suspect apps on the google play store and looking at screen shots to identify which app was adding the offending icon. Thanks again for everyone's help.
    07-16-2013 10:23 AM
  1. Can't identify this icon in my status bar? Wavy N shape?
    By nadiainthesky in forum HTC One M7
    Last Post: 04-03-2015, 05:27 AM
  2. What app for tracking how many miles I've walked?
    By angelxx in forum Samsung Galaxy Note 2
    Last Post: 07-12-2013, 08:12 AM
  3. What is "Showcase"??
    By tmac9wr in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 07-11-2013, 01:28 PM
  4. Screen lock and battery question
    By 1ton in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 07-11-2013, 12:54 PM
