Re: Google+ Location help
As an update to this, I have been using location a lot and noticed that it doesn't auto update locations and there is no option. Keep hitting refresh and eventually it changes.
It also occasionally re-asks whether you want to turn on location sharing, (even when it is on), when you keep hitting refresh.
Ermmm, looks like an update has arrived for Google maps... Nice design. Also, the settings now has an option to select to say whether this tablet reports location.
Sounds positive, we will have to test when out tomorrow.
G+ = +1
I assume judging by the views and no replies, no one either has a comment on this or uses it. But we find it very useful.
Anyway, an update after the new map ver.
Went out today and watched the location screen while travelling and I was not updated on the map at all, for about an hour.
BUT, my partner, on her basic phone, was updated constantly and was with the vehicle all the way to the destination.
I'm on android ver 4.1.2, she is on 2.0.2..
Both same 3g network..
Confusing.......
