1. SuperCK's Avatar
    I had to wipe my device and i'm re-downloading stuff from google play store. When I DL stuff it would automatically create a shortcut of he app on my desktop. I no longer have this option. Does something need to be turned on?
    Galaxy S4
    07-18-2013 03:29 AM
  2. B. Diddy's Avatar
    Open Google Play, tap the menu button, select Settings, then make sure "Auto-add widgets" is checked. It's a bit of a misnomer--"widgets" should be "shortcuts."
    Sent from my DROID RAZR using AC Forums mobile app
    07-18-2013 03:48 AM
  3. SuperCK's Avatar
    Thank You sir.
    B. Diddy likes this.
    07-18-2013 10:03 AM
  1. New to the tablet world, will the Nexus 7 meet my needs?
    By starski304 in forum Google Nexus 7 Tablet (2012)
    Last Post: 07-24-2013, 09:49 PM
  2. Best way to end call
    By cara10 in forum Samsung Galaxy S4
    Last Post: 07-18-2013, 03:38 AM
  3. Is there a way to turn the menu button into a multitasking button?
    By Roundpotato in forum Samsung Galaxy S4
    Last Post: 07-18-2013, 03:17 AM
  4. Refuses to charge.
    By Taylor Zamora in forum Samsung Galaxy S4
    Last Post: 07-17-2013, 11:56 PM
