pretty simple, my computer flips out after i yank the USB out of my tower (says no no don't do that you'll break it), but i'm i've already unmounted so is it necessary to eject your USB slot with android phones
thanks
thanks
^ This. To be safe, you really should eject/remove from the PC before unmounting to allow the PC to complete any pending writes. Your Android device has no idea what's going on while the card is mounted.I usually use safe removal for everything though, having a write-cached external harddrive taught me that one.
