data doesn't reconnect after being switched off for a few hours
Josef Korea
4
I am running android 4.0 on a huawei ascend g600.
Sometimes I switch data off for a few hours so I don't waste data. I do this by "disabling" The data switch. When it cpmes time to switch it back on, the mobile data doesnt reconnect until i restart the phone
I have enabled "always on mobile data"
Anything else i need to do?
srkmagnus
Retired Moderator
May 23, 2010
13,434
210
When you switch data back on try switching airplane mode off then on. See if this helps regain data without having to restart the device.
Golfdriver97
Trusted Member Team Leader
Moderator
Dec 4, 2012
35,365
110
63
srkmagnus may be on to something. There may be a bug in the software that doesn't correlate what you are trying to do with reconnecting and turning airplane mode on then off will force the radios to reconnect.
Scott Kenyon
2,060
No idea if getting to airplane mode is easy on your device. I've never used a Huawei tbh. If you have to dig through menus you may wish to consider downloading Power Toggles. It's a free app that puts the toggles in your pull down menu or on your homescreen. Would save you a bunch of taps possibly.
Phantom3SE
