1. bigbird3141's Avatar
    I have a Nexus 4 running stock 4.2.2. I first used it with a PAYG SIM to test network coverage etc. When I decided to switch network permanently I got a new SIM and switched my existing long-term number, ditching the PAYG SIM.
    Settings/About Phone/Status still reports the first SIM's phone number and IMEI. (The IMEI on the new SIM agrees with that attached to my account.)
    How can I make Settings/About Phone/Status display the correct info? I know my own phone number, but it's a pain in the backside ejecting the SIM.
    (Other "info" apps also mis-report the numbers.)
    Thanks
    07-25-2013 09:36 AM
  2. TropicalSammich's Avatar
    I'm severely confused by your question.
    The IMEI will never change, this is static to the device.
    The SIM & Phone number are reported via the SIM that's inputted, and refreshed usually by the network once you begin placing and receiving calls, voice mails, etc.
    What ever active phone number is on the SIM card in the phone, is the one that will be used to make and receive calls, regardless if your seeing something different, on a stock, unaltered phone.
    SIM card is the master, phone is the slave.
    07-25-2013 12:36 PM
  3. bigbird3141's Avatar
    Thanks. Sorry I thought SIM and IMEI were synonymous. My bad.
    SIM number only seems available via an app, not Android direct. And I guess I'll just have to put up with the phone number not being correct.
    Bb
    Sent from my Nexus 4 using AC Forums mobile app
    07-25-2013 02:25 PM
  4. DenverRalphy's Avatar
    Have you tried a factory reset after changing SIM?
    SwiftKeyed/Flowed via Tapatalk 4 Beta.
    07-25-2013 03:55 PM
  5. rootedVette's Avatar
    Perhaps the device isn't the problem? Maybe the service provider accidentally provisioned the SIM with your old number. When you call someone, does the new number show up on their caller ID?
    Posted via Android Central App on Manta Ray
    07-25-2013 04:01 PM
  6. tahera Monirul j8w's Avatar
    Software ta ke
    12-29-2017 03:19 AM
  1. maximum number of rollout firmware updates exceeded??
    By Joe Vile in forum Samsung Galaxy S4
    Last Post: 07-03-2014, 05:47 AM
  2. Import only phone numbers to Acura?
    By Eclipse2K in forum Samsung Galaxy Note 2
    Last Post: 07-26-2013, 09:51 PM
  3. Need Help Using Mobile Hotspot Outside of the Verizon Network
    By MeisterJ89 in forum Verizon Droid DNA
    Last Post: 07-26-2013, 10:32 AM
  4. Rumor: Apple to drop iPhone 5 in favor of 'iPhone 5S'*
    By quest7 in forum General News & Discussion
    Last Post: 07-26-2013, 07:44 AM
  5. The worst tech headlines
    By hallda01 in forum General News & Discussion
    Last Post: 07-25-2013, 09:00 AM
