1. umer yes's Avatar
    i got my note 2 yesterday and i used it the whole day with wifi constantly on(browsing), listening to music, with sync off everything is perfect the only that bugs me is the fact that it only lasted 5 to 6 hours.Does your note 2 last the same when using it heavy or is there something wrong with my battery or phone? and one thing more, when i view my battery drain apps, google chrome is usually the 2nd or 3rd on the list, is this normal? honestly i was expecting much more from this phone battery wise....thanks
    07-31-2013 03:11 PM
  2. JoyXiao's Avatar
    U can try to look for a extended battery for back-up, I have one on order.
    08-01-2013 04:12 AM
  3. msndrstood's Avatar
    It depends on what you have running, signal strength, on screen time, settings etc.
    I am a heavy user and on stock I could get 5+ hours on screen time with stock battery if I use Wi-Fi. I'm in a weak signal area so on 3G I would get 3-4 hours on screen time.
    I don't like to worry about battery life, so I choose to get a 6500 mAh extended battery. Now I get 8-9 hours of on screen time. I'm happy with it and I like the bulk.
    Screenshots of your battery stats would help us determine what would help improve your battery life.
    Sent via Note II
    08-01-2013 08:27 AM
  4. srkmagnus's Avatar
    Browsing and listening to music can put a strain on the device. There ways to help you conserve battery life as much as possible by doing a few simple things that are clearly explained in this thread:
    http://forums.androidcentral.com/gen...ving-tips.html
    If you have questions feel free to aks or post in the above thread.
    08-01-2013 09:30 AM
  1. Verizon Galaxy S3 : Battery status icon won't go away!
    By Nussbuss in forum Verizon Galaxy S III
    Last Post: 05-30-2014, 07:07 AM
  2. good and secure note app.
    By steveinil in forum Android Apps
    Last Post: 03-04-2014, 12:31 AM
  3. Help Me Convince UAG to Create A Galaxy Note 8 Case
    By harryhoudini66 in forum Samsung Galaxy Note 8.0 Tablet
    Last Post: 08-06-2013, 03:28 PM
  4. LG Optimus Pro and Galaxy S4 NFC Share.
    By TTheInfamous1 in forum LG Optimus G Pro
    Last Post: 07-31-2013, 06:25 PM
  5. Looking for a Note owner for a favour
    By jwn66 in forum Samsung Galaxy Note 8.0 Tablet
    Last Post: 07-31-2013, 06:13 PM
