1. Hawk Jordan's Avatar
    Hi all. Recently I bought a sencor element 7 v3 but it's with Android 4.0 and it drains the battery and since it has only 1.2 on it's processor it is pretty slow. I want to downgrade it a bit. If anyone could help me I'd appreciat it. Thanks for your time.
    Full specs:
    7 "
    Resolution: 800x480 pixels
    CPU: A13 1.2 GHz
    RAM: 512 MB DDR3
    Integrated 4 GB memory
    Operation system: Android 4.0 (ICS)
    FLASH 10.4 support
    G sensor for automatic display rotation
    Micro SDHC card slot (up to 32 GB)
    Front panel camera for video chats (0.3 MPx)
    Integrated WIFI module (802.11 b/g/n)
    Supported formats:
    Video: H.264, H.263, VC-1, MPEG-1/2/4, DivX, XviD, WMV7/8, VP6, AVS, etc.
    Audio: MP3, WMA, OGG, FLAC, APE, AAC, AC3, ATRA, DTS, etc.
    Pictures: JPEG, BMP, GIF, PNG etc.
    E-Books: EPUB, PDF, FB2, PDB, CHM, HTML, TXT, UMD, WORD, EXCELL etc.
    Recording function (MP3)
    USB 2.0
    08-01-2013 07:01 AM
  2. Imad Khalfan's Avatar
    So , did u get any info about your query . I am using the same tablet and facing the same issues. If you get any info on it ,pease do let me know.
    Regards
    Imad khalfan
    08-16-2013 10:54 AM
  3. B. Diddy's Avatar
    Perhaps these tips might help?
    http://forums.androidcentral.com/gen...ving-tips.html
    08-16-2013 06:52 PM
  1. [ROM] [E739 & E730] PenberRom2 [PA+AOKP+CM9] V3.7
    By LeoLawliet in forum LG myTouch
    Last Post: 01-11-2014, 07:54 PM
  2. Element cases now available for the S4
    By thehatguy in forum Samsung Galaxy S4
    Last Post: 08-01-2013, 06:43 PM
  3. New Nexus 7 has no NFC secure element, No Google Wallet support.
    By chowdog13 in forum Google Nexus 7 Tablet (2013)
    Last Post: 08-01-2013, 09:50 AM
  4. Replies: 0
    Last Post: 07-10-2013, 03:22 PM
  5. [SOLVED] Flashed EG4T-EL29-directbootCWM-v3.tar.md5 using ODIN Mobile, and now stuck in CWM menu
    By Dark Penguin in forum Epic 4G Touch Rooting, ROMs, and Hacks
    Last Post: 07-05-2013, 04:21 PM
